Saltar al contenido principal
HP G72 Memory Module Replacement
Qué necesitas
  1. HP G72 Memory Module Replacement, Memory Module: paso 1, imagen 1 de 3 HP G72 Memory Module Replacement, Memory Module: paso 1, imagen 2 de 3 HP G72 Memory Module Replacement, Memory Module: paso 1, imagen 3 de 3
    • Shut down the computer. Disconnect all external devices connected to the computer. Disconnect the power from the computer by first disconnecting the power cord from the AC outlet and then disconnecting the AC adapter from the computer.
    • Turn the computer so that it faces upside down. Position the computer with the front toward you.
    • Slide the battery release latch to release the battery. Pivot the battery to remove it.
    • Loosen the three Phillips M2.5×6.0 captive screws that secure the memory module compartment cover.
  2. HP G72 Memory Module Replacement: paso 2, imagen 1 de 3 HP G72 Memory Module Replacement: paso 2, imagen 2 de 3 HP G72 Memory Module Replacement: paso 2, imagen 3 de 3
    • Use a plastic opening tool (or equivalent) to lift the back side of the cover. Small tabs hold the cover in place. Firmly pull up on the cover to release the tabs.
    • Remove the cover
    • Spread the retaining tabs on each side of the memory module slot to release the memory module. Remove the module as needed
Conclusión
2 personas más completaron esta guía.
oldturkey03
Miembro Desde 09/29/10
784,816 Reputación
119 Guías creadas
Equipo
Global Fixers Miembro de Global Fixers
Community
33 Miembros
572 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 21
Todo El Tiempo: 2,505
