Saltar al contenido principal
HP G71t-400 RAM Replacement
Qué necesitas
  1. HP G71t-400 RAM Replacement, RAM: paso 1, imagen 1 de 3 HP G71t-400 RAM Replacement, RAM: paso 1, imagen 2 de 3 HP G71t-400 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • Lay the laptop down so the bottom is facing up.
    • Push the slide button, circled in photo 1, to release the battery.
    • Action in picture 2 shows the direction and release.
    • Tilt the battery back in the direction it popped up in and remove the battery.
    • This ensures there is no power in the system that could potentially short out any components.
  2. HP G71t-400 RAM Replacement: paso 2, imagen 1 de 3 HP G71t-400 RAM Replacement: paso 2, imagen 2 de 3 HP G71t-400 RAM Replacement: paso 2, imagen 3 de 3
    • Remove the circled screws.
    • Lift and remove the cover, exposing the RAM cards.
  3. HP G71t-400 RAM Replacement: paso 3, imagen 1 de 1
    • Push in the silver tabs to release the RAM.
    • When they pop up from the locked position the RAM may be removed.
Conclusión
Nicholas Castro
Miembro Desde 03/24/19
711 Reputación
6 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 95
