Saltar al contenido principal
HP G71t-300 Cooling Fan Replacement
Qué necesitas
  1. HP G71t-300 Cooling Fan Replacement, Keyboard: paso 1, imagen 1 de 3 HP G71t-300 Cooling Fan Replacement, Keyboard: paso 1, imagen 2 de 3 HP G71t-300 Cooling Fan Replacement, Keyboard: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Ground yourself by either touching an unpainted metal surface or by using the Anti-Static wrist strap.
    • Turn off the computer and remove the charger from the charging port.
    • Turn the laptop over and slide the battery release catch to the right. The battery will pop up from its slot. Remove it using your fingers.
  2. HP G71t-300 Cooling Fan Replacement: paso 2, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the four screws from the indicated cover.
    • Gently lift and remove the cover.
  3. HP G71t-300 Cooling Fan Replacement: paso 3, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 3, imagen 2 de 2
    • Remove the five 6mm screws with the Phillips #0 screwdriver.
  4. HP G71t-300 Cooling Fan Replacement: paso 4, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 4, imagen 2 de 2
    • Pry the keyboard off with a spudger. Be careful not to apply too much pressure and damage any components.
  5. HP G71t-300 Cooling Fan Replacement: paso 5, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 5, imagen 2 de 2
    • Disconnect the clip attaching the keyboard wiring to the motherboard. Lift and remove the keyboard.
  6. HP G71t-300 Cooling Fan Replacement, Cooling Fan: paso 6, imagen 1 de 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: paso 6, imagen 2 de 3 HP G71t-300 Cooling Fan Replacement, Cooling Fan: paso 6, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the 6mm screw from the top panel.
    • Gently lift and remove the panel. Use a metal spudger if the it seems set in place.
  7. HP G71t-300 Cooling Fan Replacement: paso 7, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 7, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the 6mm screw for the Wi-Fi module cover.
    • Remove the cover.
  8. HP G71t-300 Cooling Fan Replacement: paso 8, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 8, imagen 2 de 2
    • Remove all fourteen 6mm screws using a Phillips #0 screwdriver.
  9. HP G71t-300 Cooling Fan Replacement: paso 9, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 9, imagen 2 de 2
    • Partially separate the two panels until connectors are visible.
    • Unclip the wires that attach the trackpad module to the motherboard.
  10. HP G71t-300 Cooling Fan Replacement: paso 10, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 10, imagen 2 de 2
    • Remove the five highlighted screws using a Phillips #0 screwdriver.
  11. HP G71t-300 Cooling Fan Replacement: paso 11, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 11, imagen 2 de 2
    • Disconnect the five cables by gently pulling them from their slots.
  12. HP G71t-300 Cooling Fan Replacement: paso 12, imagen 1 de 2 HP G71t-300 Cooling Fan Replacement: paso 12, imagen 2 de 2
    • Press a metal spudger between the VGA port and the plastic housing to pry up the motherboard.
    • Remove the motherboard and turn it so that the fan is facing upward.
  13. HP G71t-300 Cooling Fan Replacement: paso 13, imagen 1 de 3 HP G71t-300 Cooling Fan Replacement: paso 13, imagen 2 de 3 HP G71t-300 Cooling Fan Replacement: paso 13, imagen 3 de 3
    • Use a Phillips #0 screwdriver to loosen the three screws attaching the heatsink to the motherboard.
    • Remove the heatsink and fan assembly by unclipping the fan from the motherboard.
Conclusión
Rohan Mathew
Miembro Desde 09/22/16
513 Reputación
5 Guías creadas
Equipo
UC Davis, Team 2-3, Oliver Fall 2016 Miembro de UC Davis, Team 2-3, Oliver Fall 2016
UCD-OLIVER-F16S2G3
5 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 225
