Introducción
Hi everyone, here I am with a new guide.
I hope you will like the guide. It's based mostly on this one: HP G62-453 Teardown
Good luck.
Qué necesitas
First of all, we will remove the battery and open up the 2 panels at the bottom of the laptop. You'll see the RAM, HDD and Wifi.
This is the step where we will remove the screws from the whole case.
First remove the screws in the battery compartment.
Remove the rest of the case screws. There is one screw at the top left corner not shown in the pictures
There are 2 hidden screws in the HDD compartment. ( M2.5x6.5)
Now remove the usb conncetor + the dc jack connector.
After removing all the cables/ wires and screws, we can remove the screws from the screen hinge. It should only be needed to remove the screws on the left hinge.
Remove the motherboard by pulling it up and sliding it to the right. you might need to move the screen a few mm so you can slide the motherboard free.
Now re-assemble the laptop. Just reverse everything you did.
When you have screwed on the heatsink hold the fan with a finger and blast the heatsink fins with compressed air to get any dirt out. you might have to blow from both sides of the fins to get trapped dirt out.
Give case a short blast of air also to get dirt out... also blast the connectors as they are good at collecting dust and dirt
7 personas más completaron esta guía.
