Saltar al contenido principal
HP G62-234DX Screen Replacement
Qué necesitas
  1. HP G62-234DX Screen Replacement, Screen: paso 1, imagen 1 de 3 HP G62-234DX Screen Replacement, Screen: paso 1, imagen 2 de 3 HP G62-234DX Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Make sure the computer is turned off and disconnected from a charger.
    • Place your laptop on a clean, flat surface with the bottom facing up.
    • Slide the battery lock to the left.
    • Slide the battery out from the laptop while holding the lock to the left.
    • Remove the battery.
  2. HP G62-234DX Screen Replacement: paso 2, imagen 1 de 3 HP G62-234DX Screen Replacement: paso 2, imagen 2 de 3 HP G62-234DX Screen Replacement: paso 2, imagen 3 de 3
    • Flip over the laptop and open the laptop.
    • Using a spudger and opening picks, loosen the screen bezel (outer frame).
    • Start from one side of the bezel and work your way around to the other side.
  3. HP G62-234DX Screen Replacement: paso 3, imagen 1 de 3 HP G62-234DX Screen Replacement: paso 3, imagen 2 de 3 HP G62-234DX Screen Replacement: paso 3, imagen 3 de 3
    • Lift the screen bezel with your fingers to reveal the screen unit.
  4. HP G62-234DX Screen Replacement: paso 4, imagen 1 de 2 HP G62-234DX Screen Replacement: paso 4, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove one 4.0 mm screw on the left and right hinges.
    • Lift the hinges with your fingers.
  5. HP G62-234DX Screen Replacement: paso 5, imagen 1 de 2 HP G62-234DX Screen Replacement: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the two 3.0 mm screws on the top of the display.
  6. HP G62-234DX Screen Replacement: paso 6, imagen 1 de 2 HP G62-234DX Screen Replacement: paso 6, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove a total of four 3.0 mm screws along the edge of both sides of the screen.
  7. HP G62-234DX Screen Replacement: paso 7, imagen 1 de 3 HP G62-234DX Screen Replacement: paso 7, imagen 2 de 3 HP G62-234DX Screen Replacement: paso 7, imagen 3 de 3
    • Carefully loosen the adhesive under the screen unit using your spudger.
    • Pull off the screen unit using your fingers.
    • The screen is still connected by the display cable.
  8. HP G62-234DX Screen Replacement: paso 8, imagen 1 de 3 HP G62-234DX Screen Replacement: paso 8, imagen 2 de 3 HP G62-234DX Screen Replacement: paso 8, imagen 3 de 3
    • To disconnect the display cable connector, gently push the tip of a spudger under the clip. Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
    • Lift the protective film slightly and, holding the clip and cable together, gently pull in the direction of the cable to remove the connector from its socket.
    • Safely remove the screen.
Conclusión
Una persona más ha completado esta guía.
Kate Ferland
Miembro Desde 11/01/23
836 Reputación
6 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Petersen Fall 2023 Miembro de UMass Dartmouth, Team 1-1, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 153
