Saltar al contenido principal
HP G62-234DX Hard Drive Replacement
Qué necesitas
  1. HP G62-234DX Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the computer is turned off, disconnected from the charger, and on a steady surface.
    • Unlock the battery by sliding the button just below it, to the left.
  2. HP G62-234DX Hard Drive Replacement: paso 2, imagen 1 de 1
    • While pushing the lock button to the unlock position, slide the battery out and away from the laptop.
    • When sliding the new battery back into the socket, you'll know it's secure when you hear a click.
  3. HP G62-234DX Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 HP G62-234DX Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 HP G62-234DX Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • It Is recommended to remove the RAM panel for easier access when removing the hard drive panel.
    • Use a Phillips #0 screwdriver to remove the two screws securing the hard drive panel on the back of the laptop.
    • Use a spudger to remove hard drive panel and carefully lift it up and out.
  4. HP G62-234DX Hard Drive Replacement: paso 4, imagen 1 de 1
    • Pull the hard drive from the SATA connector to remove the hard drive from the laptop.
Conclusión
Cameron Popillo
Miembro Desde 03/20/23
337 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 98
