Saltar al contenido principal
HP G62-223CL Optical Drive Replacement
Qué necesitas
  1. HP G62-223CL Optical Drive Replacement, Battery Removal: paso 1, imagen 1 de 2 HP G62-223CL Optical Drive Replacement, Battery Removal: paso 1, imagen 2 de 2
    • Removing the battery while the laptop is still on may corrupt your files.
    • Turn the device over to expose the bottom of the device.
    • Slide the battery release all the way to the left.
    • There will be a click and the battery will be released from its compartment.
  2. HP G62-223CL Optical Drive Replacement: paso 2, imagen 1 de 1
    • Carefully remove the battery from its compartment.
  3. HP G62-223CL Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 1
    • Locate two Phillips head retaining screws which secure the hard drive compartment.
    • Use a Phillips #0 screwdriver to loosen the retaining screws.
    • Remove the panel covering the compartment.
    • Ground yourself before attempting to touch any components. To ground yourself, touch a conductive metal to eliminate any static buildup in your body, which can damage computer components.
  4. HP G62-223CL Optical Drive Replacement: paso 4, imagen 1 de 1
    • Locate the 6 mm Phillips head screw to the left of the hard drive.
    • Use a Phillips #0 screwdriver to remove the screw.
  5. HP G62-223CL Optical Drive Replacement: paso 5, imagen 1 de 2 HP G62-223CL Optical Drive Replacement: paso 5, imagen 2 de 2
    • Once the screw is removed, use a plastic opening tool and place it between the body of the computer and the optical drive.
    • Apply enough pressure to loosen the optical drive.
    • The optical drive can then be removed by hand.
Conclusión
Garret Layton
Miembro Desde 01/13/15
669 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 1-4, Sullivan Winter 2015 Miembro de USF Tampa, Team 1-4, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G4
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 1,224
