Saltar al contenido principal
HP G62-144DX RAM Replacement
Qué necesitas
  1. HP G62-144DX RAM Replacement, Battery: paso 1, imagen 1 de 2 HP G62-144DX RAM Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX RAM Replacement, RAM: paso 2, imagen 1 de 3 HP G62-144DX RAM Replacement, RAM: paso 2, imagen 2 de 3 HP G62-144DX RAM Replacement, RAM: paso 2, imagen 3 de 3
    • Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but will come loose from the body of the laptop.
    • Use a plastic opening tool to gently pry the panel free from the laptop.
  3. HP G62-144DX RAM Replacement: paso 3, imagen 1 de 3 HP G62-144DX RAM Replacement: paso 3, imagen 2 de 3 HP G62-144DX RAM Replacement: paso 3, imagen 3 de 3
    • Pull the two metal clips to the top RAM module outwards parallel to the laptop.
    • After the RAM module pops up, gently pull in out from the computer.
    • Repeat for the second RAM module.
Conclusión
Cameron Moran
Miembro Desde 10/18/17
623 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 345
