Introducción
The hard drive is where all of the data on the computer is stored. Follow this guide to replace the hard drive in the HP G62-144DX
Qué necesitas
Slide the lock to the right, located slightly above the battery location.
While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
Gently remove the panel with a plastic opening tool.
