Saltar al contenido principal
HP G62-144DX Hard Drive Replacement
Qué necesitas
  1. HP G62-144DX Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 HP G62-144DX Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure to turn off the laptop before removing the battery.
    • Slide the lock to the right, located slightly above the battery location.
    • While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
  2. HP G62-144DX Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 3 HP G62-144DX Hard Drive Replacement, Hard Drive: paso 2, imagen 2 de 3 HP G62-144DX Hard Drive Replacement, Hard Drive: paso 2, imagen 3 de 3
    • Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
    • The screws will stay in the panel, but come free from the body of the computer.
    • Gently remove the panel with a plastic opening tool.
  3. HP G62-144DX Hard Drive Replacement: paso 3, imagen 1 de 3 HP G62-144DX Hard Drive Replacement: paso 3, imagen 2 de 3 HP G62-144DX Hard Drive Replacement: paso 3, imagen 3 de 3
    • Unscrew the three 3x4 Phillips screws holding the hard drive in with a Phillips #1 screwdriver.
    • Pull the hard drive cable out of the motherboard.
    • Pull the hard drive out of the computer.
Conclusión
Cameron Moran
Miembro Desde 10/18/17
623 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 340
