Saltar al contenido principal
HP G62 347NR Keyboard Replacement
Qué necesitas
  1. HP G62 347NR Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Make sure the device is turned off before removing the battery to avoid loss or corruption of files.
    • Turn the device over so the bottom is facing up.
    • Slide the battery release to the left until you hear a click.
    • Once you hear a click, the battery will have been released from the battery compartment.
  2. HP G62 347NR Keyboard Replacement: paso 2, imagen 1 de 1
    • Remove the battery, carefully, from the compartment.
  3. HP G62 347NR Keyboard Replacement: paso 3, imagen 1 de 2 HP G62 347NR Keyboard Replacement: paso 3, imagen 2 de 2
    • Find the hard drive compartment with two Phillips head screws.
    • Use the PH1 screwdriver to loosen and remove both screws.
    • Gently remove the hard drive compartment.
  4. HP G62 347NR Keyboard Replacement: paso 4, imagen 1 de 2 HP G62 347NR Keyboard Replacement: paso 4, imagen 2 de 2
    • Locate the three Phillips head screws on the compartment with the wifi and keyboard logos.
    • Using the Phillips #1 screwdriver, remove the three screws.
  5. HP G62 347NR Keyboard Replacement: paso 5, imagen 1 de 2 HP G62 347NR Keyboard Replacement: paso 5, imagen 2 de 2
    • Locate the two keyboard logos on back of the computer.
    • Find the Phillips head screws in the hole next to the logo.
    • Remove the two screws using a Phillips #1 screwdriver.
  6. HP G62 347NR Keyboard Replacement: paso 6, imagen 1 de 2 HP G62 347NR Keyboard Replacement: paso 6, imagen 2 de 2
    • In the battery compartment, locate the three keyboard logos.
    • Find the Phillips head screws next to each logo.
    • Remove the three screws using the Phillips #1 screwdriver.
  7. HP G62 347NR Keyboard Replacement: paso 7, imagen 1 de 2 HP G62 347NR Keyboard Replacement: paso 7, imagen 2 de 2
    • Place the plastic opening tool between the keyboard and the motherboard.
    • Gently pry the entire keyboard up and away from the laptop's motherboard.
    • Once you have part of the keyboard separated, run your fingers around the edge of the keyboard to separate the entire thing.
Conclusión
3 personas más completaron esta guía.
McKenzi Morris
Miembro Desde 10/10/16
511 Reputación
3 Guías creadas
Equipo
Texas Tech, Team 6-1, Bennett Fall 2016 Miembro de Texas Tech, Team 6-1, Bennett Fall 2016
TTU-BENNETT-F16S6G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 2,740
