Saltar al contenido principal
HP G60T-600 CTO Power Button Frame Replacement
Qué necesitas
  1. HP G60T-600 CTO Power Button Frame Replacement, Battery: paso 1, imagen 1 de 1
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. HP G60T-600 CTO Power Button Frame Replacement: paso 2, imagen 1 de 2 HP G60T-600 CTO Power Button Frame Replacement: paso 2, imagen 2 de 2
    • Place your index finger on the ridged tab.
  3. HP G60T-600 CTO Power Button Frame Replacement: paso 3, imagen 1 de 1
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. HP G60T-600 CTO Power Button Frame Replacement, Keyboard: paso 4, imagen 1 de 2 HP G60T-600 CTO Power Button Frame Replacement, Keyboard: paso 4, imagen 2 de 2
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. HP G60T-600 CTO Power Button Frame Replacement: paso 5, imagen 1 de 1
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. HP G60T-600 CTO Power Button Frame Replacement: paso 6, imagen 1 de 1
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A plastic opening tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. HP G60T-600 CTO Power Button Frame Replacement: paso 7, imagen 1 de 2 HP G60T-600 CTO Power Button Frame Replacement: paso 7, imagen 2 de 2
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
  8. HP G60T-600 CTO Power Button Frame Replacement, Power Button Frame: paso 8, imagen 1 de 1
    • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
  9. HP G60T-600 CTO Power Button Frame Replacement: paso 9, imagen 1 de 2 HP G60T-600 CTO Power Button Frame Replacement: paso 9, imagen 2 de 2
    • Gently pull the white tab upwards.
    • With similar force, pull the connection out.
    • You are now free to pull the power button frame off of your device.
  10. HP G60T-600 CTO Power Button Frame Replacement: paso 10, imagen 1 de 1
    • Unscrew the 5mm screw holding the CD player in place.
Conclusión
Equipo
UMass Dartmouth, Team 4-5, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 150
