Saltar al contenido principal
Introducción
You will be removing and replacing your CD player from the device.
Partes
No se especificaron partes.
  1. Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Failure to remove the battery before performing any replacement guide may result in electric shock.
    • Close your device, then turn it over.
  2. Place your index finger on the ridged tab. Place your index finger on the ridged tab.
    • Place your index finger on the ridged tab.
  3. Apply moderate pressure to the tab and slide it to the right.
    • Apply moderate pressure to the tab and slide it to the right.
    • While the tab is on the right, you should be able to gently slide your battery out of your device.
  4. Unscrew the following 5mm screws with a #0 Phillips screwdriver. Unscrew the following 5mm screws with a #0 Phillips screwdriver.
    • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
  5. Turn your laptop over and open it up.
    • Turn your laptop over and open it up.
    • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
  6. Pull up on the top of your keyboard with medium force. It should start to pop out.
    • Pull up on the top of your keyboard with medium force. It should start to pop out.
    • A plastic opening tool may facilitate this task.
    • Run your hands underneath the edges of the keyboard until it is free from the device.
    • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
  7. Place your thumbs on the two small, white tabs. Push these tabs forward to release the connection and free the keyboard from the device.
    • Place your thumbs on the two small, white tabs.
    • Push these tabs forward to release the connection and free the keyboard from the device.
  8. Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
    • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
  9. Gently pull the white tab upwards. With similar force, pull the connection out.
    • Gently pull the white tab upwards.
    • With similar force, pull the connection out.
    • You are now free to pull the power button frame off of your device.
  10. Unscrew the 5mm screw holding the CD player in place.
    • Unscrew the 5mm screw holding the CD player in place.
  11. Slide the CD player case away from the device with medium-hard force, it should come right out. Slide the CD player case away from the device with medium-hard force, it should come right out. Slide the CD player case away from the device with medium-hard force, it should come right out.
    • Slide the CD player case away from the device with medium-hard force, it should come right out.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 4-5, Catania Fall 2016 Miembro de UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 60
