Saltar al contenido principal
HP G60-443CL Battery Replacement
Qué necesitas
  1. HP G60-443CL Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the laptop upside down where the headphone and auxiliary jack are facing you.
  2. HP G60-443CL Battery Replacement: paso 2, imagen 1 de 1
    • In the top left corner, there is a lever that has a small picture of a battery on it. Slide the lever to the left.
  3. HP G60-443CL Battery Replacement: paso 3, imagen 1 de 1
    • Once you have slid the lever to the left, the front part of the battery will be released and you should be able to grab the released part of the battery with your thumb.
  4. HP G60-443CL Battery Replacement: paso 4, imagen 1 de 1
    • The battery can then be pulled out of its compartment by hand.
Conclusión
Alora Allen
Miembro Desde 11/06/17
101 Reputación
1 Guía escrita
Equipo
Baylor, Team S8-G7, Johnson Fall 2017 Miembro de Baylor, Team S8-G7, Johnson Fall 2017
BU-JOHNSON-F17S8G7
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 314
