1. First, remove the battery to avoid electric shock Slide and unlock the battery, then lift it Slide and unlock the battery, then lift it
    • First, remove the battery to avoid electric shock
    • Slide and unlock the battery, then lift it
  2. Now, you should to remove the Wi-Fi card cover Remove this screw Lift the cover
    • Now, you should to remove the Wi-Fi card cover
    • Remove this screw
    • Lift the cover
  3. The Wi-Fi card is locked, but you should to change that. Remove this two little screws. Pull the Wi-Fi card.
    • The Wi-Fi card is locked, but you should to change that.
    • Remove this two little screws.
    • Pull the Wi-Fi card.
  4. ¡Envío gratuito para todos los pedidos de más de USD100.00 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    Todos somos Genios
  5. You should to be carefull with the next steps, the plugs are easy to separate, but they are fragile Pull carefully both cables from the Wi-Fi card, it requires a little strength Pull carefully both cables from the Wi-Fi card, it requires a little strength
    • You should to be carefull with the next steps, the plugs are easy to separate, but they are fragile
    • Pull carefully both cables from the Wi-Fi card, it requires a little strength
  6. Now it's time to put the new Wi-Fi card Connect both plugs, the cable with white tag, at the left of the Wi-Fi card, the green one, at the right plug
    • Now it's time to put the new Wi-Fi card
    • Connect both plugs, the cable with white tag, at the left of the Wi-Fi card, the green one, at the right plug
  7. The Wi-Fi card already has the power plugs, now it's time to the data plug Insert the Wi-Fi card in a 45 degrees angle Now press it and screw it
    • The Wi-Fi card already has the power plugs, now it's time to the data plug
    • Insert the Wi-Fi card in a 45 degrees angle
    • Now press it and screw it
  8. For finish, reassemble the cover If the cover is still lifted, press softly until you hear a click If the cover is still lifted, press softly until you hear a click
    • For finish, reassemble the cover
    • If the cover is still lifted, press softly until you hear a click
Linea de Meta
5 personas más completaron esta guía.
jimenezser
Miembro Desde 29/08/12
3,538 Reputación
4 Guías creadas
If the button that turns blue when I start my computer stays orange does that mean I need to install a new wifi card?
veronica - Contestar
Hi frnd just want to know ur hp laptop button was not working it stayed orange thn what did u do? U changed wifi card or button plz reply me i have same condition can u ans me on my mobile whatsapp plz +85254077440
saqib raheem -
Please provide information on the model of the wifi card
thaisabs - Contestar
My card wifi on laptop G60-530US was not working. Can you suggest me some modle of new card wifi which can be suitable my laptop. Thanks so much
tech - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 5
Últimos 30 Días: 23
Todo El Tiempo: 3,011
