Saltar al contenido principal
HP Flyer Red Optical Disc Drive Replacement
Qué necesitas
  1. HP Flyer Red Optical Disc Drive Replacement, Battery: paso 1, imagen 1 de 2 HP Flyer Red Optical Disc Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure your laptop is powered off.
    • With laptop closed flip to look at the underside of the laptop.
  2. HP Flyer Red Optical Disc Drive Replacement: paso 2, imagen 1 de 1
    • On the underside of the laptop towards the hinge for the screen there are two rectangular slide switches located inside of rectangular tracks.
  3. HP Flyer Red Optical Disc Drive Replacement: paso 3, imagen 1 de 2 HP Flyer Red Optical Disc Drive Replacement: paso 3, imagen 2 de 2
    • The left switch is the battery unlock switch.
    • Inside the rectangular track of this switch there is an image of a closed lock that should be visible. Push this switch to the other end of the track and an image of an open lock should be visible.
  4. HP Flyer Red Optical Disc Drive Replacement: paso 4, imagen 1 de 1
    • Then take and slide the other switch to the other end of its track which will pop out the battery.
    • Grab the battery and pull it out of the slot.
  5. HP Flyer Red Optical Disc Drive Replacement, Optical Disc Drive: paso 5, imagen 1 de 1
    • Remove the 4mm Phillips #1 screw located towards the middle of the laptop slightly towards the right with the picture of the CD next to it.
  6. HP Flyer Red Optical Disc Drive Replacement: paso 6, imagen 1 de 2 HP Flyer Red Optical Disc Drive Replacement: paso 6, imagen 2 de 2
    • Slide the disc tray out of the its slot.
Conclusión
2 personas más completaron esta guía.
Anthony Ciotti
Miembro Desde 04/07/16
747 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 847
