Saltar al contenido principal
HP Envy x360 m6-w105dx Keyboard Replacement
Qué necesitas
  1. HP Envy x360 m6-w105dx Keyboard Replacement, Keyboard: paso 1, imagen 1 de 3 HP Envy x360 m6-w105dx Keyboard Replacement, Keyboard: paso 1, imagen 2 de 3 HP Envy x360 m6-w105dx Keyboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Make sure the laptop is powered off and disconnected from any outlets.
    • Use the opening pick to lift up the eight rubber grips on the underside of the device.
    • With the #1 Phillips screwdriver, remove the twelve 6mm screws from the back case.
  2. HP Envy x360 m6-w105dx Keyboard Replacement: paso 2, imagen 1 de 2 HP Envy x360 m6-w105dx Keyboard Replacement: paso 2, imagen 2 de 2
    • Open the laptop and turn to the keyboard.
    • Gently insert an opening pick into the edge of the keyboard panel, and slide around the keyboard lining until the clips have all been disengaged.
    • Lift the keyboard panel from the bottom and carefully start to lift up.
    • There are ribbon cables still connected on the under side of the the keyboard. Do not pull the keyboard away from the device.
  3. HP Envy x360 m6-w105dx Keyboard Replacement: paso 3, imagen 1 de 2 HP Envy x360 m6-w105dx Keyboard Replacement: paso 3, imagen 2 de 2
    • Gently lift the keyboard up from the bottom.
    • Carefully open the locking flap of the three ZIF connectors and detach the three ribbon cables from the motherboard using your fingers.
    • Do not remove the ZIF connectors by pulling on the wires, instead detach them by gently flipping up the plastic tabs located at the ends of the wiring.
    • Fully remove the keyboard from the laptop and install your new keyboard.
Conclusión
Una persona más ha completado esta guía.
4 comentarios
This guide is not complete.
Alex Watkins - Contestar
Hi ..I need to buy keyboard for my laptop .. how can I get one please?
Alquraini - Contestar
This seems to gloss over a lot of important steps and details, “Fully remove the keyboard from the laptop and install your new keyboard.“
Keyboard is attached by plastic tabs, not screws. How do I remove and install the new keyboard?
Janet Schexnayder - Contestar
Hello please i need to buy keyboard for my laptop envy 15x360
Model 15-u280nb. Please how can i get it
nurugee4luv - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 28
Todo El Tiempo: 3,468
