Introducción
This replacement guide is for the speakers of the HP Envy x360 m6-w103dx. All you need to complete this guide is a plastic opening tool, a #0 Phillips screwdriver, a #00 Phillips screwdriver, and an anti-static wrist strap.
If you suspect there are issues with the speakers, please refer to the troubleshooting guides here.
Wear the anti-static wrist strap and attach it to a metal surface to avoid damaging sensitive electrical components. Make sure the computer is unplugged and powered off before touching any internal parts.
The speakers aren’t hazardous components to handle.
Qué necesitas
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
Disconnect the connector on the left speaker by gently pulling on each side of the connector.
