Saltar al contenido principal
HP Envy x360 m6-w103dx Memory (RAM) Replacement
Qué necesitas
  1. HP Envy x360 m6-w103dx Memory (RAM) Replacement, Keyboard: paso 1, imagen 1 de 2 HP Envy x360 m6-w103dx Memory (RAM) Replacement, Keyboard: paso 1, imagen 2 de 2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 2, imagen 1 de 2 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 2, imagen 2 de 2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 3, imagen 1 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 3, imagen 2 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 3, imagen 3 de 3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Memory (RAM) Replacement, Motherboard: paso 5, imagen 1 de 1
    • Disconnect the pin head battery connection to remove power from the motherboard.
    • Unscrew the five 4mm screws holding the motherboard in place using a #0 Phillips screwdriver.
    • It's possible the positions of the screws will be different on your board. If the motherboard resists lifting, double-check that all screws have been removed.
  6. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 6, imagen 3 de 3
    • Remove the five flat ribbon cables by gently lifting the head of the cable up and back.
    • Remove the two remaining multicolored ribbon cables by pulling the white plastic head backwards.
    • Do not pull directly on the wires.
    • If the head of the multicolored ribbon cable doesn't come out, try gently wiggling it side to side as you pull.
  7. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 7, imagen 1 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 7, imagen 2 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 7, imagen 3 de 3
    • Lift the motherboard up from the left side at a shallow angle.
    • Gently pull the motherboard to the left and gently wiggle it side to side until the ports on the right side of the board detach from the case.
    • Ensure the laptop is well supported, as the motherboard is a heavy component and removing it may make the laptop off-balance.
  8. HP Envy x360 m6-w103dx Memory (RAM) Replacement, Memory (RAM): paso 8, imagen 1 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement, Memory (RAM): paso 8, imagen 2 de 3 HP Envy x360 m6-w103dx Memory (RAM) Replacement, Memory (RAM): paso 8, imagen 3 de 3
    • Carefully lay the motherboard on a flat surface with the metal plate facing up.
    • Remove the metal plate from the eight surrounding inserts.
    • It should lift directly off of the motherboard without much fuss.
  9. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 9, imagen 1 de 2 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 9, imagen 2 de 2
    • Move the two locking tabs on either side of the RAM stick away from each other.
    • The RAM should clear the tabs and spring up to rest at an angle to the motherboard.
  10. HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 10, imagen 1 de 2 HP Envy x360 m6-w103dx Memory (RAM) Replacement: paso 10, imagen 2 de 2
    • Gently pull the memory stick away from the memory slot with respect to the angle at which it rests.
    • To reinstall, insert the RAM stick at the same angle that it rested before, then press the stick down until the locking tabs on either side hold it down in place.
Conclusión
3 personas más completaron esta guía.
Steven Ngo
Miembro Desde 10/10/19
927 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S12-G2, Regan Fall 2019 Miembro de Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
4 Miembros
23 Guías creadas
Un comentario
Great tutorial! The only things that weren't mentioned are the fact that you have to detach the little metal wires from the Wi-Fi card in the top-right of the motherboard, and you also have to take out the audio jack if you want to lay the motherboard upside down. Otherwise, this was exactly what I was looking for. Thanks!
Aleksandr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 34
Todo El Tiempo: 1,386
