Saltar al contenido principal
HP Envy x360 m6-w103dx Hard Drive Replacement
Qué necesitas
  1. HP Envy x360 m6-w103dx Hard Drive Replacement, Keyboard: paso 1, imagen 1 de 2 HP Envy x360 m6-w103dx Hard Drive Replacement, Keyboard: paso 1, imagen 2 de 2
    • Before you begin, be sure to power off your laptop.
    • Using an opening pick, remove the 4 rubber feet and 4 screw covers.
  2. HP Envy x360 m6-w103dx Hard Drive Replacement: paso 2, imagen 1 de 2 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 2, imagen 2 de 2
    • Unscrew the twelve 6 mm screws from the bottom of the laptop using a Phillips #0 screwdriver.
  3. HP Envy x360 m6-w103dx Hard Drive Replacement: paso 3, imagen 1 de 3 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 3, imagen 2 de 3 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 3, imagen 3 de 3
    • Open the laptop carefully, with the keyboard face up.
    • Pry around the outside of the keyboard with the plastic opening tool until the keyboard can be lifted slightly.
    • When lifting the keyboard do not pull too hard. There are cables that must be disconnected before the keyboard can be removed.
  4. HP Envy x360 m6-w103dx Hard Drive Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 4, imagen 3 de 3
    • Lift the keyboard until you can see the cables connected to the motherboard.
    • Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
    • Detach the keyboard.
  5. HP Envy x360 m6-w103dx Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 2 HP Envy x360 m6-w103dx Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 2
    • Disconnect the connector by pushing up the white tab directly above the hard drive.
    • Gently lift the connector to disconnect.
  6. HP Envy x360 m6-w103dx Hard Drive Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-w103dx Hard Drive Replacement: paso 6, imagen 3 de 3
    • Using the plastic opening tool, gently lift the hard drive.
    • Remove the hard drive by lifting it from the other components.
Conclusión
4 personas más completaron esta guía.
Steven Ngo
Miembro Desde 10/10/19
927 Reputación
7 Guías creadas
Equipo
Cal Poly, Team S12-G2, Regan Fall 2019 Miembro de Cal Poly, Team S12-G2, Regan Fall 2019
CPSU-REGAN-F19S12G2
4 Miembros
23 Guías creadas
2 comentarios
Does this laptop have m2 slot? Or sata?
Dhakichiki Dhakichiki - Contestar
For anyone else wondering: This laptop (m6-w103dx) does not have an m2 slot. It only has a 2.5" SATA bay. I replaced the built-in HDD (Toshiba) with a Crucial MX500 and it works perfectly. Pair this guide with the RAM upgrade one by the same author (it supports up to 16 GB, two 8 GB sticks) and you have yourself a much faster laptop.
Aleksandr - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 49
Todo El Tiempo: 2,047
