Saltar al contenido principal
HP Envy x360 m6-aq105dx Hard Drive Replacement
Qué necesitas
  1. HP Envy x360 m6-aq105dx Hard Drive Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Hard Drive Replacement: paso 2, imagen 1 de 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 1
    • Attach the grounding bracelet s clip to the frame of the laptop then put on the grounding bracelet.
    • Remove the two 4.6mm screws securing the hard drive in place using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Hard Drive Replacement: paso 4, imagen 1 de 1
    • Disconnect the cable plugged into the hard drive and remove the hard drive from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 556
