Saltar al contenido principal
HP Envy x360 m6-aq105dx Battery Replacement
Qué necesitas
  1. HP Envy x360 m6-aq105dx Battery Replacement, Back Cover: paso 1, imagen 1 de 1
    • Ground yourself by touching a metal object or surface. This prevents electrical damage to other components in the laptop.
    • Remove the two 7.8 mm screws using the Phillips #0 screwdriver.
    • Remove the six 5.2 mm screws using the Torx T5 screwdriver.
  2. HP Envy x360 m6-aq105dx Battery Replacement: paso 2, imagen 1 de 1
    • Light to moderate force is required to remove the back cover.
    • Insert the Jimmy in between the frame of the laptop and the removable back cover and remove the back cover from the device.
  3. HP Envy x360 m6-aq105dx Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Attach the grounding bracelet's clip to the frame of the laptop, then put on the grounding bracelet.
    • Remove the six 4.6mm screws securing the battery using the Phillips #0 screwdriver.
  4. HP Envy x360 m6-aq105dx Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the power supply cable connected to the motherboard.
  5. HP Envy x360 m6-aq105dx Battery Replacement: paso 5, imagen 1 de 2 HP Envy x360 m6-aq105dx Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 20
Todo El Tiempo: 1,153
