Saltar al contenido principal
HP Envy x360 m6-aq103dx Wireless Module Replacement
Qué necesitas
  1. HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: paso 1, imagen 1 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: paso 1, imagen 2 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 2, imagen 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 3, imagen 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Wireless Module Replacement, Battery: paso 5, imagen 1 de 2 HP Envy x360 m6-aq103dx Wireless Module Replacement, Battery: paso 5, imagen 2 de 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 7, imagen 1 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 7, imagen 2 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 7, imagen 3 de 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: paso 8, imagen 1 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: paso 8, imagen 2 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement, Intel Wireless Module: paso 8, imagen 3 de 3
    • Remove the two antenna cables connected to the wireless module by wedging the small plastic opening tool between the cables and the wireless module and lifting up.
  9. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 9, imagen 1 de 1
    • Remove the 3.5 mm Phillips Head screw with the Phillip Head 1 screwdriver.
  10. HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 10, imagen 1 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 10, imagen 2 de 3 HP Envy x360 m6-aq103dx Wireless Module Replacement: paso 10, imagen 3 de 3
    • Slide the wireless module towards the back of the computer to remove it.
Conclusión
2 personas más completaron esta guía.
Joey Chen
Miembro Desde 10/02/17
316 Reputación
2 Guías creadas
Equipo
Cal Poly, Team S4-G3, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Miembros
9 Guías creadas
Un comentario
@jchen202 Just curious, what is the Battery Wattage of this HP Envy? I noticed your guide contains a glimpse of the DC IN CONNECTOR , which seems to be identical to my HP ENVY X360 - 15M-BP112DX. How idid your repairs turn out? If possible, would you be able to provide a picture of the DC IN Connector?
Al N - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 18
Todo El Tiempo: 1,103
