Saltar al contenido principal
HP Envy x360 m6-aq103dx Headphone Jack Replacement
Qué necesitas
  1. HP Envy x360 m6-aq103dx Headphone Jack Replacement, Bottom Cover: paso 1, imagen 1 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Bottom Cover: paso 1, imagen 2 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Headphone Jack Replacement, Battery: paso 5, imagen 1 de 2 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Battery: paso 5, imagen 2 de 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 7, imagen 1 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 7, imagen 2 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 7, imagen 3 de 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Headphone Jack Replacement, Headphone Jack: paso 8, imagen 1 de 2 HP Envy x360 m6-aq103dx Headphone Jack Replacement, Headphone Jack: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Anti-Static Wrist Strap
    $7.95
    • Make sure you are wearing an anti-static wrist strap.
    • Remove the four screws from the blue board that contains the headphone jack using the Phillips head 1 screwdriver (one 4 mm black screw, one 3 mm black screw, and two 4.5 mm silver screws).
  9. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 9, imagen 1 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 9, imagen 2 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 9, imagen 3 de 3
    • Insert the plastic opening tool underneath the connector on the black flexible flat cable with the blue plastic stripe.
    • Lift the opening tool to open the connector.
    • Use your fingers to slide the ribbon cable out of the connector.
  10. HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 10, imagen 1 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 10, imagen 2 de 3 HP Envy x360 m6-aq103dx Headphone Jack Replacement: paso 10, imagen 3 de 3
    • Hold the left side of the board between your fingers.
    • Lift the edge upwards enough to clear the other components in the way.
    • Be gentle when lifting to avoid breaking the board.
    • Slide and rotate to lift the board out of the designated slot for the board.
    • You may have to wiggle the board back and forth, and up and down, to remove the board.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team S4-G3, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 16
Todo El Tiempo: 1,613
