Saltar al contenido principal
HP Envy x360 m6-aq103dx Display Replacement
Qué necesitas
  1. HP Envy x360 m6-aq103dx Display Replacement, Bottom Cover: paso 1, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement, Bottom Cover: paso 1, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Display Replacement: paso 2, imagen 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Display Replacement: paso 3, imagen 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Display Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Display Replacement, Battery: paso 5, imagen 1 de 2 HP Envy x360 m6-aq103dx Display Replacement, Battery: paso 5, imagen 2 de 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Display Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Display Replacement: paso 7, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 7, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 7, imagen 3 de 3
    • Lift the battery out of the laptop with your hands.
  8. HP Envy x360 m6-aq103dx Display Replacement, Display: paso 8, imagen 1 de 2 HP Envy x360 m6-aq103dx Display Replacement, Display: paso 8, imagen 2 de 2
    • Click the back cover on so none of the internal components are damaged during the following steps.
    • Open the display, so it is flat and the screen is facing up.
    • Put the suction cup in the middle of the screen.
  9. HP Envy x360 m6-aq103dx Display Replacement: paso 9, imagen 1 de 2 HP Envy x360 m6-aq103dx Display Replacement: paso 9, imagen 2 de 2
    • Wedge the small plastic opening tool between the frame and the screen and pry it open by lifting up.
  10. HP Envy x360 m6-aq103dx Display Replacement: paso 10, imagen 1 de 2 HP Envy x360 m6-aq103dx Display Replacement: paso 10, imagen 2 de 2
    • Slide the tool around the edge of the frame while pulling on the suction cup.
    • Popping sounds are ok.
  11. HP Envy x360 m6-aq103dx Display Replacement: paso 11, imagen 1 de 1
    • Take the suction cup off before laying the screen on the keyboard.
  12. HP Envy x360 m6-aq103dx Display Replacement: paso 12, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 12, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 12, imagen 3 de 3
    • Remove the grey tape covering the wires by pulling on the tab slowly (located at the bottom of the display.
    • Detach the grey tape and the clear tape by wedging the small blue opening tool under the tape enough to raise a corner and pull the tape off with your hand.
    • Remove the tape slowly to avoid separating the adhesive.
    • Do this for both pieces of tape that cover wires.
  13. HP Envy x360 m6-aq103dx Display Replacement: paso 13, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 13, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 13, imagen 3 de 3
    • For the round cable underneath the smaller of the two pieces of tape, remove the cable by sliding it backwards.
    • Remove the other cable by pulling on the tape downwards and backwards.
  14. HP Envy x360 m6-aq103dx Display Replacement: paso 14, imagen 1 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 14, imagen 2 de 3 HP Envy x360 m6-aq103dx Display Replacement: paso 14, imagen 3 de 3
    • Lift the screen up with your hands.
Conclusión
12 personas más completaron esta guía.
Equipo
Cal Poly, Team S4-G3, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Miembros
9 Guías creadas
8 comentarios
Thank you for this. I was getting REAL nervous as I got to the bottom portion of the screen. It really looks like the bottom is a separate panel (with screws under it) - Your photos assured me that it was not, so I gave it a little more and she came right off. Excellent work and photos!
[Only edit would be, no need to take the battery out, just disconnect]
Kyle B - Contestar
Where can I get the screen to buy online please, I am from Africa
aholylier - Contestar
Amazon or Ebay work. Just be sure your getting a screen with the proper resolution. You can inspect the connector to see what one you have if you dont know (the pin configuration is slightly diferent)
Kyle B - Contestar
which resolution requires what pins
Chris Henrie -
do you know the part number of the display for this laptop?
Debbie Endara - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 28
Ultimos 30 días: 55
Todo El Tiempo: 14,932
