Saltar al contenido principal
HP Envy x360 m6-aq103dx CPU Fan Replacement
Qué necesitas
  1. HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: paso 1, imagen 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: paso 1, imagen 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 2, imagen 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 3, imagen 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: paso 5, imagen 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: paso 5, imagen 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement, CPU Fan: paso 5, imagen 3 de 3
    • Put on the anti-static wristband first
    • Disconnect the port of the fan by flipping the black tab with the small blue plastic opening tool.
    • Remove the cable from the connector.
  6. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 6, imagen 3 de 3
    • Peel back a little bit of the grey tape connected to the round cable with the big blue opening tool.
    • Using your fingers, peel the tape off of the body of the computer.
    • Peel slowly to avoid separating the adhesive.
  7. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 7, imagen 1 de 2 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 7, imagen 2 de 2
    • Remove the black cable from the fan by unclicking it from the plastic body of the fan with your fingers and move it out of the area.
    • There will be clicking sounds when the black cable is removed.
  8. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 8, imagen 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 8, imagen 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 8, imagen 3 de 3
    • Disconnect the port with the red yellow and blue wires by dislodging the wires with your fingers.
  9. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 9, imagen 1 de 1
    • Remove the two 4.5mm Phillips #1 screws.
  10. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 10, imagen 1 de 1
    • Loosen the four black screws by the curved heat sink with a Phillips head 1 screwdriver.
    • These screws do not come off.
  11. HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 11, imagen 1 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 11, imagen 2 de 3 HP Envy x360 m6-aq103dx CPU Fan Replacement: paso 11, imagen 3 de 3
    • Lift the CPU fan out with your hand.
Conclusión
4 personas más completaron esta guía.
Equipo
Cal Poly, Team S4-G3, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Miembros
9 Guías creadas
3 comentarios
Step 5-7 can be bypassed I didn’t need to do it
diego.montenegro23 - Contestar
My first home repair so far. Really easy to follow guide. Great job!
Caleb Robinson - Contestar
Purchased tools and did the steps, no issues. worth the tools to use later. Worked in iT anyways.
Roy Rodgers - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 16
Todo El Tiempo: 4,605
