Saltar al contenido principal
HP Envy x360 m6-aq103dx Bottom Cover Replacement
Qué necesitas
  1. HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: paso 1, imagen 1 de 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: paso 1, imagen 2 de 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Bottom Cover Replacement: paso 2, imagen 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Bottom Cover Replacement: paso 3, imagen 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Bottom Cover Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-aq103dx Bottom Cover Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
Conclusión
8 personas más completaron esta guía.
Sarah Samora
Miembro Desde 10/02/17
789 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G3, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Miembros
9 Guías creadas
4 comentarios
what should I do if I don’t have a nylon spudger? Is it safe to use my fingers to pry it open? I know I need to be careful about static or else it could fry the comp.
Joshua Bowman - Contestar
It was really easy to open.
[deleted] - Contestar
Glad I read this…didn't know about the 2 screws under the grip pads. Once again the internet comes through.
MrHarris73 - Contestar
But where can i purchase the bottom cover
imran abdulhameed - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 24
Ultimos 30 días: 57
Todo El Tiempo: 9,093
