Saltar al contenido principal
HP Envy x360 m6-aq103dx Battery Replacement
Qué necesitas
  1. HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: paso 1, imagen 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: paso 1, imagen 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement, Bottom Cover: paso 1, imagen 3 de 3
    • Flip the laptop over to expose the underside.
    • Remove the two grip pads with blue plastic opening tool by inserting the tool between the laptop and the pads and slowly lifting up.
    • The grip pads are tacky, remove slowly to avoid separating the adhesive.
  2. HP Envy x360 m6-aq103dx Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 8 mm Phillips Head screws that were under the grip pads using a Phillip's Head 1 Screwdriver.
  3. HP Envy x360 m6-aq103dx Battery Replacement: paso 3, imagen 1 de 1
    • Remove the six 5 mm Torx screws using a T5 Torx Screwdriver.
  4. HP Envy x360 m6-aq103dx Battery Replacement: paso 4, imagen 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement: paso 4, imagen 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement: paso 4, imagen 3 de 3
    • Use the nylon spudger to pop off the bottom cover by inserting it into the heat vent and twisting to the left or right.
    • You may hear a slight clicking or popping, but that is normal.
  5. HP Envy x360 m6-aq103dx Battery Replacement, Battery: paso 5, imagen 1 de 2 HP Envy x360 m6-aq103dx Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Use the Phillips Head 1 Screwdriver to remove the six 4 mm screws.
  6. HP Envy x360 m6-aq103dx Battery Replacement: paso 6, imagen 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement: paso 6, imagen 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement: paso 6, imagen 3 de 3
    • Disconnect the battery port from the motherboard by gently lifting it on both sides with the plastic opening tool.
    • Lift up the port with the tool.
  7. HP Envy x360 m6-aq103dx Battery Replacement: paso 7, imagen 1 de 3 HP Envy x360 m6-aq103dx Battery Replacement: paso 7, imagen 2 de 3 HP Envy x360 m6-aq103dx Battery Replacement: paso 7, imagen 3 de 3
    • Lift the battery out of the laptop with your hands.
Conclusión
6 personas más completaron esta guía.
Sarah Samora
Miembro Desde 10/02/17
789 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S4-G3, Livingston Fall 2017 Miembro de Cal Poly, Team S4-G3, Livingston Fall 2017
CPSU-LIVINGSTON-F17S4G3
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 14
Ultimos 30 días: 31
Todo El Tiempo: 7,700
