Introducción
The power port is essential in recharging the computer's battery. This guide will explain how to properly remove and replace the power port component of the computer.
Qué necesitas
Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
Use a JIS #1 screwdriver to remove the 4.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 7.7mm screws from the indicated positions.
Use the JIS #1 screwdriver to remove the 4.4mm screws from the indicated positions.
