Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
Most of the replaceable components in a laptop is through the back panel. Therefore, this guide will show how to remove it properly.
  1. Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top. Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
    • Use the plastic opening tool to remove the gray rubber pads on the bottom of the laptop. For our device we only needed to remove the two at the top.
  2. Use a Torx T5 screwdriver to remove the six 5.1 mm screws. Use a JIS #1 screwdriver to remove the two 7.2mm screws. Use a JIS #1 screwdriver to remove the two 7.2mm screws.
    • Use a Torx T5 screwdriver to remove the six 5.1 mm screws.
    • Use a JIS #1 screwdriver to remove the two 7.2mm screws.
  3. Use a plastic opening tool to pry open the case. Go slowly around the edge.  You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
    • Use a plastic opening tool to pry open the case. Go slowly around the edge. You will hear popping noises, such are due to popping open the small joints that keep the cover attached.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S13-G17, Cagle Fall 2017 Miembro de USF Tampa, Team S13-G17, Cagle Fall 2017
USFT-CAGLE-F17S13G17
4 Miembros
7 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 38
Ultimos 30 días: 128
Todo El Tiempo: 1,677
