Saltar al contenido principal
HP Envy x360 15m-cn0012dx TrackPad Replacement
Qué necesitas
  1. HP Envy x360 15m-cn0012dx TrackPad Replacement, TrackPad: paso 1, imagen 1 de 2 HP Envy x360 15m-cn0012dx TrackPad Replacement, TrackPad: paso 1, imagen 2 de 2
    • Make sure the computer is turned off, and remove all cables.
    • Set the laptop face down.
    • Peel back the grey screw guards, along the top and bottom edge of the back case. It may be helpful to use a spudger to get started.
    • Peel slowly to avoid tearing the rubber covers.
  2. HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #0 screwdriver, remove the seven 5mm screws from the back case.
  3. HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 3, imagen 1 de 3 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 3, imagen 2 de 3 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 3, imagen 3 de 3
    • Pry open the back cover using the iFixit Opening Tool.
    • While using the tool, place a pick at each corner of the computer (be careful and do it slowly).
    • Once all the corners are slightly lifted, carefully pop off the back cover.
  4. HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 4, imagen 1 de 2 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 4, imagen 2 de 2
    • The battery rest above the trackpad and connects to the black port with the gold pins at the bottom right corner of the motherboard.
    • Remove the screws around the perimeter of the battery holding it down with a Phillips #0 screwdriver.
    • Disconnect the battery cable from the motherboard.
    • Remove the battery by lifting it out of the laptop case.
  5. HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 5, imagen 1 de 2 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 5, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws from the metal plate covering the bottom edge of the trackpad.
    • Using a Phillips #0 screwdriver, remove the three 4mm screws from the top edge of the trackpad.
    • Remove the metal plate.
  6. HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 6, imagen 1 de 3 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 6, imagen 2 de 3 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 6, imagen 3 de 3
    • Use the iFixit opening tool, lift up the black lock tab of the ZIF connector.
    • Pull out the ribbon cable from the trackpad connector.
  7. HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 7, imagen 1 de 2 HP Envy x360 15m-cn0012dx TrackPad Replacement: paso 7, imagen 2 de 2
    • Remove the trackpad from the device, lifting the bottom edge first.
Conclusión
Grace Daleki
Miembro Desde 02/04/20
475 Reputación
3 Guías creadas
Equipo
UW Stout, Team S1-G3, Schneider-Bateman Spring 2020 Miembro de UW Stout, Team S1-G3, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 16
Todo El Tiempo: 711
