Introducción
Speakers are responsible for all audio output on the computer, any damage can cause distortions or cutting of audio . Use this guide to replace your speaker.
Qué necesitas
On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
Using a Phillips #1, remove the seven M2.0x3.2 screws.
Undo the six connections using the blue opening tool.
Use the tweezers to remove the cords from their restraints.
Lift the speakers out of the laptop.
