Saltar al contenido principal
HP Envy x360 15m-bq021dx Power Input Replacement
Qué necesitas
  1. HP Envy x360 15m-bq021dx Power Input Replacement, Battery: paso 1, imagen 1 de 2 HP Envy x360 15m-bq021dx Power Input Replacement, Battery: paso 1, imagen 2 de 2
    • On the back panel of the device, remove the four (4) M2.5xL6 screws at the top of the photo using a Phillips #0 screwdriver.
    • Unscrew the three (3) screws at the bottom of the photo using a T5 Torx screwdriver.
  2. HP Envy x360 15m-bq021dx Power Input Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bq021dx Power Input Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bq021dx Power Input Replacement: paso 2, imagen 3 de 3
    • To remove the back cover, use the black spudger to lift up on the edges of the cover.
    • Use a suction cup to assist in lifting the back cover
  3. HP Envy x360 15m-bq021dx Power Input Replacement: paso 3, imagen 1 de 1
    • Use the Philips #0 screwdriver to remove six (6) M2.0x3.2 screws from battery.
  4. HP Envy x360 15m-bq021dx Power Input Replacement: paso 4, imagen 1 de 1
    • Using the Philips #0 screwdriver, remove the final screw from the battery connected to the SSD storage unit.
  5. HP Envy x360 15m-bq021dx Power Input Replacement: paso 5, imagen 1 de 1
    • Lift and pull the front of the battery up and out (away from the connector) to remove.
  6. HP Envy x360 15m-bq021dx Power Input Replacement, Cooling Fan: paso 6, imagen 1 de 2 HP Envy x360 15m-bq021dx Power Input Replacement, Cooling Fan: paso 6, imagen 2 de 2
    • Using a Philips #0 screwdriver, remove the three M2x4 screws located around the cooling fan as shown in this picture.
    • Be careful as the fan might be sharp in some places when removing it.
  7. HP Envy x360 15m-bq021dx Power Input Replacement: paso 7, imagen 1 de 2 HP Envy x360 15m-bq021dx Power Input Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove the connector clip with the tweezers.
  8. HP Envy x360 15m-bq021dx Power Input Replacement: paso 8, imagen 1 de 1
    • Remove the four spring loaded screws with a Philips #1 screwdriver.
  9. HP Envy x360 15m-bq021dx Power Input Replacement: paso 9, imagen 1 de 2 HP Envy x360 15m-bq021dx Power Input Replacement: paso 9, imagen 2 de 2
    • Remove the cooling fan.
  10. HP Envy x360 15m-bq021dx Power Input Replacement, Motherboard: paso 10, imagen 1 de 3 HP Envy x360 15m-bq021dx Power Input Replacement, Motherboard: paso 10, imagen 2 de 3 HP Envy x360 15m-bq021dx Power Input Replacement, Motherboard: paso 10, imagen 3 de 3
    • Using a Phillips #1, remove the seven M2.0x3.2 screws.
    • Undo the six connections using the blue opening tool.
  11. HP Envy x360 15m-bq021dx Power Input Replacement: paso 11, imagen 1 de 3 HP Envy x360 15m-bq021dx Power Input Replacement: paso 11, imagen 2 de 3 HP Envy x360 15m-bq021dx Power Input Replacement: paso 11, imagen 3 de 3
    • Carefully remove the aux port from the frame of the computer as shown.
  12. HP Envy x360 15m-bq021dx Power Input Replacement: paso 12, imagen 1 de 2 HP Envy x360 15m-bq021dx Power Input Replacement: paso 12, imagen 2 de 2
    • Pull the mother board up and away from frame of the computer.
  13. HP Envy x360 15m-bq021dx Power Input Replacement, Speakers: paso 13, imagen 1 de 1
    • Use the tweezers to remove the cords from their restraints.
    • Lift the speakers out of the laptop.
  14. HP Envy x360 15m-bq021dx Power Input Replacement, Power Input: paso 14, imagen 1 de 3 HP Envy x360 15m-bq021dx Power Input Replacement, Power Input: paso 14, imagen 2 de 3 HP Envy x360 15m-bq021dx Power Input Replacement, Power Input: paso 14, imagen 3 de 3
    • Remove the three M2.0x3.2 hinge screws next to the power input cord using a Philips #0 screwdriver.
    • Pry the hinge up so that it is out of the way.
  15. HP Envy x360 15m-bq021dx Power Input Replacement: paso 15, imagen 1 de 3 HP Envy x360 15m-bq021dx Power Input Replacement: paso 15, imagen 2 de 3 HP Envy x360 15m-bq021dx Power Input Replacement: paso 15, imagen 3 de 3
    • Lift out the power input.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 290
