Saltar al contenido principal
HP Envy x360 15m-bp112dx Screen Assembly Replacement
Qué necesitas
  1. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 2, imagen 3 de 3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 3, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 3, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 3, imagen 3 de 3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 4, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 4, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 5, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 5, imagen 2 de 2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
  6. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Fan: paso 6, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Fan: paso 6, imagen 2 de 2
    • Carefully peel back the tape connecting the heat sink to the fan assembly.
    • Loosen the four 1 mm Phillips screws retaining the fan assembly.
    • Remove the three 2 mm Phillips screws.
  7. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 7, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 7, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 7, imagen 3 de 3
    • Unplug the thin cable connected to the fan, pulling horizontally.
    • Carefully peel back the connected tape.
  8. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 8, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 8, imagen 2 de 2
    • Carefully remove the fan assembly by pulling on it upwards.
    • When reassembling, ensure that you clean off and replace the thermal paste on the fan assembly.
  9. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Motherboard: paso 9, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Motherboard: paso 9, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Motherboard: paso 9, imagen 3 de 3
    • Remove the two 5 mm Phillips screws from the first speaker.
    • Carefully peel back the tape.
  10. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 10, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 10, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 10, imagen 3 de 3
    • Open the tab connected to the right speaker cord, prying it with a plastic opening tool upwards.
    • Pull out the speaker cord horizontally.
  11. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 11, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 11, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 11, imagen 3 de 3
    • Remove the thin cable from the speaker, pulling it out horizontally.
  12. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 12, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 12, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 12, imagen 3 de 3
    • Remove the right speaker, pulling upward carefully.
    • While pulling on the speaker, unwind the cord around the plastic clips to free the speaker and place it to the side.
  13. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 13, imagen 1 de 1
    • Remove the twelve 2.5 mm Phillips screws.
  14. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 14, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 14, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 14, imagen 3 de 3
    • Unclip the ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
    • Remove the ribbon cable by pulling it out horizontally.
  15. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 15, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 15, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 15, imagen 3 de 3
    • Unclip the second ribbon cable using a plastic opening tool to flip the black ZIF connector locking flap up.
  16. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 16, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 16, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 16, imagen 3 de 3
    • Unclip the third ribbon cable using a plastic opening tool to flip up the black ZIF connector locking flap.
  17. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 17, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 17, imagen 2 de 2
    • Remove the thin cable carefully by pulling out horizontally in line with its slot.
  18. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 18, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 18, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 18, imagen 3 de 3
    • Unclip the fourth ribbon cable using a plastic opening tool to flip up the black ZIF connector.
  19. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 19, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 19, imagen 2 de 2
    • Carefully remove the motherboard by pulling upwards on it.
  20. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Speakers: paso 20, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Speakers: paso 20, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Speakers: paso 20, imagen 3 de 3
    • The removal of the right speaker is located in the motherboard guide during steps 1-4.
    • Remove the two 1.5 mm Phillips screws.
    • Carefully peel the tape back.
    • Pull the left speaker cord around the plastic clips.
  21. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 21, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 21, imagen 2 de 2
    • Carefully remove the left speaker by pulling up vertically.
  22. HP Envy x360 15m-bp112dx Screen Assembly Replacement, Screen Assembly: paso 22, imagen 1 de 2 HP Envy x360 15m-bp112dx Screen Assembly Replacement, Screen Assembly: paso 22, imagen 2 de 2
    • Remove the four 5 mm Phillips screws.
    • Remove the one 5 mm Phillips screw.
    • Carefully remove the Wi-Fi card, lifting upwards.
  23. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 23, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 23, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 23, imagen 3 de 3
    • Disconnect the wires from the Wi-Fi card by using an opening tool and pulling the wires upwards.
  24. HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 24, imagen 1 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 24, imagen 2 de 3 HP Envy x360 15m-bp112dx Screen Assembly Replacement: paso 24, imagen 3 de 3
    • Unscrew the four 5 mm Phillips screws.
    • Separate the screen from the rest of the laptop by opening the laptop like a book and pushing the two parts away from each other.
Conclusión
James Bonnell
Miembro Desde 03/20/23
355 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 10
Ultimos 30 días: 21
Todo El Tiempo: 538
