Saltar al contenido principal
HP Envy x360 15m-bp112dx Hard Drive Replacement
Qué necesitas
  1. HP Envy x360 15m-bp112dx Hard Drive Replacement, Hard Drive: paso 1, imagen 1 de 1
    • Power off the laptop before starting the disassembly.
    • Start by facing the device upside down with the hinge facing away from you.
    • Remove the seven 1 mm Phillips screws.
  2. HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 2, imagen 1 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 2, imagen 2 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 2, imagen 3 de 3
    • Use an opening tool to pry the back panel by pushing the bottom cover upwards.
    • Place the bottom cover away from the laptop.
  3. HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 3, imagen 1 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 3, imagen 2 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 3, imagen 3 de 3
    • Carefully remove the sata ribbon cable from the hard drive, pulling it out horizontally.
    • To avoid injury, ensure that you disconnect the battery prior to removing any of the cables in the laptop.
  4. HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 4, imagen 1 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 4, imagen 2 de 3 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 4, imagen 3 de 3
    • Remove the hard drive by pulling it out vertically.
    • Remove the plastic casing around the hard drive by peeling it back.
  5. HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 5, imagen 1 de 2 HP Envy x360 15m-bp112dx Hard Drive Replacement: paso 5, imagen 2 de 2
    • Disconnect the ribbon cable by pulling it away horizontally from the hard drive.
Conclusión
Mohamed Kozamel
Miembro Desde 03/20/23
121 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 353
