Saltar al contenido principal
HP Envy x360 15-u473cl Motherboard Replacement
Qué necesitas
  1. HP Envy x360 15-u473cl Motherboard Replacement, Battery: paso 1, imagen 1 de 2 HP Envy x360 15-u473cl Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Power off your laptop before beginning disassembly.
    • Pry off the 2 rear rubber pads (closest to the laptop hinge) using the plastic opening tool to reveal two screws.
    • Remove the 2 anti-tamper proof covers using the spudger to reveal two screws.
  2. HP Envy x360 15-u473cl Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the fourteen 7mm screws using the Phillips #0 screwdriver from the bottom of the laptop.
  3. HP Envy x360 15-u473cl Motherboard Replacement: paso 3, imagen 1 de 2 HP Envy x360 15-u473cl Motherboard Replacement: paso 3, imagen 2 de 2
    • Turn the device right side up and open the lid.
    • Insert the plastic opening tool in between the keyboard plate and the base of laptop.
    • Run the tool along seem, prying up as you go.
    • Separate the keyboard plate from the base, lifting from the front.
  4. HP Envy x360 15-u473cl Motherboard Replacement: paso 4, imagen 1 de 1
    • There are 3 ribbon cables (black, white, and copper color) connecting the computer to the keyboard plate. Disconnect the 3 ribbon cables using the plastic opening tool by prying up the latches holding each cable in place.
    • Remove the keyboard plate from the device.
  5. HP Envy x360 15-u473cl Motherboard Replacement: paso 5, imagen 1 de 1
    • Remove the thick white ribbon cable covering the battery using the plastic opening tool by prying up the latches attaching each end.
  6. HP Envy x360 15-u473cl Motherboard Replacement: paso 6, imagen 1 de 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver.
  7. HP Envy x360 15-u473cl Motherboard Replacement: paso 7, imagen 1 de 1
    • Disconnect the battery from the motherboard.
    • There may be tamper-proof tape holding the battery in place. Remove the tape if present.
    • Remove the battery from the device.
  8. HP Envy x360 15-u473cl Motherboard Replacement, Fan: paso 8, imagen 1 de 1
    • Remove the three 4mm screws using the Phillips #0 screwdriver from the device fan.
  9. HP Envy x360 15-u473cl Motherboard Replacement: paso 9, imagen 1 de 2 HP Envy x360 15-u473cl Motherboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the fan from the motherboard using the spudger.
    • Remove the fan from the device.
  10. HP Envy x360 15-u473cl Motherboard Replacement, Motherboard: paso 10, imagen 1 de 2 HP Envy x360 15-u473cl Motherboard Replacement, Motherboard: paso 10, imagen 2 de 2
    • Remove the five 4mm screws with the Phillips #0 screwdriver.
    • Remove one 3mm screw with the Phillips #00 screwdriver.
  11. HP Envy x360 15-u473cl Motherboard Replacement: paso 11, imagen 1 de 2 HP Envy x360 15-u473cl Motherboard Replacement: paso 11, imagen 2 de 2
    • Disconnect the 2 white ribbon cables using the plastic opening tool.
    • Disconnect the two black cable bundles using the plastic opening tool.
  12. HP Envy x360 15-u473cl Motherboard Replacement: paso 12, imagen 1 de 3 HP Envy x360 15-u473cl Motherboard Replacement: paso 12, imagen 2 de 3 HP Envy x360 15-u473cl Motherboard Replacement: paso 12, imagen 3 de 3
    • Disconnect the charging port wire bundle from the motherboard using the plastic opening tool.
    • Disconnect the wireless card by pulling away from the black transistor using the spudger.
    • Remove the motherboard.
Conclusión
3 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 13
Todo El Tiempo: 2,300
