Saltar al contenido principal
HP Envy x360 13-y013cl Power Jack Replacement
Qué necesitas
  1. HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: paso 1, imagen 1 de 3 HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: paso 1, imagen 2 de 3 HP Envy x360 13-y013cl Power Jack Replacement, Power Jack: paso 1, imagen 3 de 3
    • Unscrew and remove the 7.8 mm screws with a T5 screwdriver.
    • Use a plastic opening tool to pry the bottom cover off the laptop.
  2. HP Envy x360 13-y013cl Power Jack Replacement: paso 2, imagen 1 de 1
    • Locate the copper-colored heat sync.
    • Use a JIS #0 screwdriver to remove the four 2.7 mm screws that secure the heatsink.
    • After removing the screws, lift the heatsink directly off the computer.
  3. HP Envy x360 13-y013cl Power Jack Replacement: paso 3, imagen 1 de 2 HP Envy x360 13-y013cl Power Jack Replacement: paso 3, imagen 2 de 2
    • Locate the right hinge just above the fan.
    • Use a JIS #0 screwdriver to remove two 4 mm screws from the hinge display assembly hinge.
    • Use a JIS #0 screwdriver to remove the 4.2 mm screw from directly below the power jack.
  4. HP Envy x360 13-y013cl Power Jack Replacement: paso 4, imagen 1 de 2 HP Envy x360 13-y013cl Power Jack Replacement: paso 4, imagen 2 de 2
    • Using the plastic black spudger, pry the hinge back as shown with the red arrow.
    • Continuing with the black plastic spudger, dislodge the power supply's metal frame from the computer.
  5. HP Envy x360 13-y013cl Power Jack Replacement: paso 5, imagen 1 de 1
    • Disconnect the EH-JST connector and remove the entire power supply from computer (metal frame, wire, and connector).
Conclusión
Petersee
Miembro Desde 03/28/23
382 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Spring 2023 Miembro de IUPUI, Team 3-2, Harley Spring 2023
IUPUI-HARLEY-S23S3G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 298
