Saltar al contenido principal
HP Envy m6-p114dx Speaker Replacement
Qué necesitas
  1. HP Envy m6-p114dx Speaker Replacement, Back Panel: paso 1, imagen 1 de 3 HP Envy m6-p114dx Speaker Replacement, Back Panel: paso 1, imagen 2 de 3 HP Envy m6-p114dx Speaker Replacement, Back Panel: paso 1, imagen 3 de 3
    • Power the device off, unplug it, and ground yourself.
  2. HP Envy m6-p114dx Speaker Replacement: paso 2, imagen 1 de 1
    • Remove the twelve screws in the back case using a Phillips #1 screwdriver.
  3. HP Envy m6-p114dx Speaker Replacement: paso 3, imagen 1 de 1
    • Carefully wedge an iFixit opening tool under the cover and slide it alongside the case to ensure that all clips are un-clipped.
  4. HP Envy m6-p114dx Speaker Replacement, Speaker: paso 4, imagen 1 de 3 HP Envy m6-p114dx Speaker Replacement, Speaker: paso 4, imagen 2 de 3 HP Envy m6-p114dx Speaker Replacement, Speaker: paso 4, imagen 3 de 3
    • Unscrew the two screws that have a pink spacer below them with a Phillips #0 screwdriver.
    • Lift directly up to remove the main speaker.
    • Gently pull the wire out of the plastic track that it's set in.
  5. HP Envy m6-p114dx Speaker Replacement: paso 5, imagen 1 de 1
    • Follow the cable around the inside of the case and remove the cable to the main board
    • Once this is removed you can fully remove the speaker!
Conclusión
Shad Padilla
Miembro Desde 08/26/19
112 Reputación
1 Guía escrita
Equipo
Gateway, Team S1-G1, Saknee Fall 2019 Miembro de Gateway, Team S1-G1, Saknee Fall 2019
GCC-SAKNEE-F19S1G1
2 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 16
Todo El Tiempo: 220
