Saltar al contenido principal
HP Envy m6-n010dx Hard Drive Replacement
Qué necesitas
  1. HP Envy m6-n010dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 3 HP Envy m6-n010dx Hard Drive Replacement, Battery: paso 1, imagen 2 de 3 HP Envy m6-n010dx Hard Drive Replacement, Battery: paso 1, imagen 3 de 3
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Hard Drive Replacement, Hard Drive: paso 2, imagen 1 de 1
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Hard Drive Replacement: paso 3, imagen 1 de 2 HP Envy m6-n010dx Hard Drive Replacement: paso 3, imagen 2 de 2
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Hard Drive Replacement: paso 4, imagen 1 de 3 HP Envy m6-n010dx Hard Drive Replacement: paso 4, imagen 2 de 3 HP Envy m6-n010dx Hard Drive Replacement: paso 4, imagen 3 de 3
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 14
Todo El Tiempo: 1,331
