Introducción
This guide demonstrates how to properly remove the fan of a HP Envy m6-n010dx. You will be using a Phillips 00 screwdriver throughout this guide.
Qué necesitas
Find the battery removal slider.
Slide it across while simultaneously popping out and removing the device's battery.
Remove the five marked screws found under the battery using a philips head screwdriver.
Remove the screws highlighted in red
Pry off with prying tool the lower two grip pads highlighted in orange
Remove the two additional screws underneath the lower grip pads
Remove the large back panel to reveal the inner workings
6 personas más completaron esta guía.
