Introducción
This guide demonstrates how to properly remove the fan of a HP Envy m6-n010dx. You will be using a Phillips 00 screwdriver throughout this guide.
  1. Find the battery removal slider. Slide it across while simultaneously popping out and removing the device's battery. Slide it across while simultaneously popping out and removing the device's battery.
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. Remove the five marked screws found under the battery using a philips head screwdriver.
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. Remove the small panel on the back by prying it off. This should reveal the hard drive. Remove the small panel on the back by prying it off. This should reveal the hard drive.
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  5. The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red. Gently pry off the cover to release the cable. Slowly lift the hard drive out and away from the device.
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  6. Remove the screws highlighted in red Pry off with prying tool the lower two grip pads highlighted in orange You may need to use more force than feels necessary
    • Remove the screws highlighted in red
    • Pry off with prying tool the lower two grip pads highlighted in orange
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  7. Locate fan Gently remove tape that hold the heatsink and fan together When reassembling , make sure to use new electrical tape so it will stick.
    • Locate fan
    • Gently remove tape that hold the heatsink and fan together
    • When reassembling , make sure to use new electrical tape so it will stick.
  8. Loosen the four screws on the heat sink indicated in picture Remove the heatsink Remove the heatsink
    • Loosen the four screws on the heat sink indicated in picture
    • Remove the heatsink
  9. Gently disconnect the wire connecting the fan to the motherboard Gently disconnect the wire connecting the fan to the motherboard
    • Gently disconnect the wire connecting the fan to the motherboard
  10. Remove screws indicated in photo. Remove fan Remove fan
    • Remove screws indicated in photo.
    • Remove fan
Conclusión
3 personas más completaron esta guía.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 30
Todo El Tiempo: 290
