Saltar al contenido principal
HP Envy m6-k022dx Heatsink Replacement
Qué necesitas
  1. HP Envy m6-k022dx Heatsink Replacement, Lower Case: paso 1, imagen 1 de 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx Heatsink Replacement: paso 2, imagen 1 de 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx Heatsink Replacement: paso 3, imagen 1 de 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx Heatsink Replacement: paso 4, imagen 1 de 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx Heatsink Replacement, CPU Fan: paso 5, imagen 1 de 1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx Heatsink Replacement: paso 6, imagen 1 de 1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx Heatsink Replacement: paso 7, imagen 1 de 1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx Heatsink Replacement: paso 8, imagen 1 de 1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
  9. HP Envy m6-k022dx Heatsink Replacement, Heatsink: paso 9, imagen 1 de 1
    • Prepare to remove the heatsink by removing the four screws that connect it to the motherboard.
    • Make sure you have a Philips 00 size screwdriver to remove the screws.
  10. HP Envy m6-k022dx Heatsink Replacement: paso 10, imagen 1 de 1
    • Unscrew all four of the screws connecting the heat sink to the CPU.
  11. HP Envy m6-k022dx Heatsink Replacement: paso 11, imagen 1 de 1
    • Lift up the heat sink by the strip of metal connecting it to the exhaust vent, and pull it away from the motherboard.
Conclusión
Una persona más ha completado esta guía.
Kareem Rigaud
Miembro Desde 03/02/17
403 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S13-G6, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 629
