Saltar al contenido principal
HP Envy m6-k022dx CPU Fan Replacement
Qué necesitas
  1. HP Envy m6-k022dx CPU Fan Replacement, Lower Case: paso 1, imagen 1 de 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CPU Fan Replacement: paso 2, imagen 1 de 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CPU Fan Replacement: paso 3, imagen 1 de 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CPU Fan Replacement: paso 4, imagen 1 de 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CPU Fan Replacement, CPU Fan: paso 5, imagen 1 de 1
    • The fan is located here. You will need to remove three screws in order to lift the fan out from the motherboard.
    • You will need a Phillips 00 size screwdriver to remove the screws.
  6. HP Envy m6-k022dx CPU Fan Replacement: paso 6, imagen 1 de 1
    • Use your screwdriver to remove the three screws connecting the fan to the motherboard.
  7. HP Envy m6-k022dx CPU Fan Replacement: paso 7, imagen 1 de 1
    • Grab the fan with your hand, and lift up and away from the motherboard.
  8. HP Envy m6-k022dx CPU Fan Replacement: paso 8, imagen 1 de 1
    • Grab the fan power connector by the wires and pull directly away from port until the cable is disconnected.
Conclusión
Una persona más ha completado esta guía.
Equipo
USF Tampa, Team S13-G6, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 806
