Saltar al contenido principal
HP Envy m6-k022dx CMOS Battery Replacement
Qué necesitas
  1. HP Envy m6-k022dx CMOS Battery Replacement, Lower Case: paso 1, imagen 1 de 1
    • There are 12 phillips head screws which need to be unscrewed before removing the backplate of the laptop.
  2. HP Envy m6-k022dx CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Next, use a size PH1 Philips head screw driver to remove the screws.
  3. HP Envy m6-k022dx CMOS Battery Replacement: paso 3, imagen 1 de 1
    • Then, use a prying tool to help uncouple the backplate.
  4. HP Envy m6-k022dx CMOS Battery Replacement: paso 4, imagen 1 de 1
    • Finally, use both hands to lift up and take off the back plate of the computer.
  5. HP Envy m6-k022dx CMOS Battery Replacement, CMOS Battery: paso 5, imagen 1 de 1
    • There is a power cord connecting the CMOS battery to the motherboard. Disconnect this cord by gently pulling it up, towards the edge of the device.
  6. HP Envy m6-k022dx CMOS Battery Replacement: paso 6, imagen 1 de 1
    • Once the connecting cord has been disconnected, gently lift the battery directly up, above the device.
    • The CMOS battery is now completely removed, and ready to be replaced.
Conclusión
3 personas más completaron esta guía.
Kareem Rigaud
Miembro Desde 03/02/17
403 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S13-G6, Cagle Spring 2017 Miembro de USF Tampa, Team S13-G6, Cagle Spring 2017
USFT-CAGLE-S17S13G6
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 2,861
