Saltar al contenido principal
HP Envy m6-k015dx Touchpad Replacement
Qué necesitas
    • Shut down the computer
    • Remove all external devices
    • Unplug the AC adapter
    • Close the computer
    • Turn it upside down
    • Remove the 12 screws from the bottom.
    • Gently remove the service cover
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws that hold the battery.
    • Gently lift the battery out of the computer.
  1. Aviso: los pasos 7-9 provienen de una guía que está marcada como "En progreso".
    • Remove the fan cable
    • Remove the 2 screws around the fan
    • Lift the fan up
    • Unscrew the 3 screws that hold the card reader board to the system
    • Raise the card reader board from the system
    • Remove the four screws that pin down the hard drive
    • Disconnect the harddrive from its connector
    • Remove the harddrive
    • Only complete this step if your computer model has a solid state drive
    • Remove the two screws at the top of the solid state drive
    • Remove the solid state drive
    • Remove the thirteen screws around the keyboard bracket
    • Gently remove the keyboard bracket from its top
    • Remove the 4 screws on the touchpad's board
    • Gently lift the touchpad board from the side that the screws were on
    • Remove the touchpad board
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 78
