Saltar al contenido principal
HP Envy m6-1105dx WLAN Card Replacement
Qué necesitas
  1. HP Envy m6-1105dx WLAN Card Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx WLAN Card Replacement: paso 2, imagen 1 de 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx WLAN Card Replacement, WLAN Card: paso 3, imagen 1 de 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx WLAN Card Replacement: paso 4, imagen 1 de 2 HP Envy m6-1105dx WLAN Card Replacement: paso 4, imagen 2 de 2
    • Use a JIS #0 screwdriver to unscrew the small cover where the WLAN card is.
    • The screw does not come out all the way so unscrew it as far as you can then try to life the cover.
  5. HP Envy m6-1105dx WLAN Card Replacement: paso 5, imagen 1 de 3 HP Envy m6-1105dx WLAN Card Replacement: paso 5, imagen 2 de 3 HP Envy m6-1105dx WLAN Card Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to gently disconnect the WLAN antenna cables.
  6. HP Envy m6-1105dx WLAN Card Replacement: paso 6, imagen 1 de 2 HP Envy m6-1105dx WLAN Card Replacement: paso 6, imagen 2 de 2
    • Remove the two PM2.0×3.0 screws that secure the WLAN module to the base using the JIS #0 screwdriver.
    • Using two fingers, grab the sides of the WLAN card and slowly pull it out.
Conclusión
Ian Mwalago
Miembro Desde 10/14/18
303 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 18
Todo El Tiempo: 658
