Saltar al contenido principal
HP Envy m6-1105dx RAM Replacement
  1. HP Envy m6-1105dx RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the computer completely off.
    • Disconnect any devices you have on it.
    • Turn the computer upside down on a flat surface.
  2. HP Envy m6-1105dx RAM Replacement: paso 2, imagen 1 de 1
    • Push the battery release latch with one hand.
    • Grab the battery with the other hand.
    • Lift out on an angle.
  3. HP Envy m6-1105dx RAM Replacement, RAM: paso 3, imagen 1 de 1
    • Release the screw in the center of the service cover.
    • Slide the battery release latch and pull cover towards you.
    • Lift cover off.
  4. HP Envy m6-1105dx RAM Replacement: paso 4, imagen 1 de 2 HP Envy m6-1105dx RAM Replacement: paso 4, imagen 2 de 2
    • Push the silver levers on either side of the memory module away from the module.
    • Remove the memory module by gently pulling it on an angle away from the slot.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 13
Todo El Tiempo: 425
