Introducción
Use this guide to replace a faulty motherboard on your HP Envy dv7t-7200 if you want an updated processor or if your motherboard shorted out.
Qué necesitas
Place the computer on its top on a flat surface with the hinges facing away from you.
Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
Remove the 2 Phillips PM2.5×5.5 top screws from brackets on both hard drives.
Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
Place the laptop on it’s top
Remove the two screws that secure the keyboard to the laptop.
Una persona más ha completado esta guía.
