Saltar al contenido principal
HP Envy dv7t-7200 Fan Replacement
Qué necesitas
  1. HP Envy dv7t-7200 Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Fan Replacement: paso 2, imagen 1 de 3 HP Envy dv7t-7200 Fan Replacement: paso 2, imagen 2 de 3 HP Envy dv7t-7200 Fan Replacement: paso 2, imagen 3 de 3
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Fan Replacement: paso 3, imagen 1 de 1
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Fan Replacement, Service Cover: paso 4, imagen 1 de 1
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Fan Replacement: paso 5, imagen 1 de 2 HP Envy dv7t-7200 Fan Replacement: paso 5, imagen 2 de 2
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Fan Replacement, Hard Drive: paso 6, imagen 1 de 1
    • Remove the 2 Phillips PM2.5×5.5 top screws from brackets on both hard drives.
  7. HP Envy dv7t-7200 Fan Replacement: paso 7, imagen 1 de 1
    • Remove the primary drive first located on the right hand side.
    • Use the black tab to lift the drive up and out.
  8. HP Envy dv7t-7200 Fan Replacement: paso 8, imagen 1 de 1
    • Remove the 2 Phillips PM2.5×5.5 screws on each side of the drive bracket.
  9. HP Envy dv7t-7200 Fan Replacement: paso 9, imagen 1 de 1
    • Remove the hard drive connector cable.
    • This cable can be difficult to remove. Try to pull this cable firmly and carefully.
  10. HP Envy dv7t-7200 Fan Replacement: paso 10, imagen 1 de 1
    • Repeat steps 6-9 for the secondary hard drive.
  11. HP Envy dv7t-7200 Fan Replacement, Optical Disc Drive: paso 11, imagen 1 de 1
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  12. HP Envy dv7t-7200 Fan Replacement: paso 12, imagen 1 de 2 HP Envy dv7t-7200 Fan Replacement: paso 12, imagen 2 de 2
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  13. HP Envy dv7t-7200 Fan Replacement: paso 13, imagen 1 de 2 HP Envy dv7t-7200 Fan Replacement: paso 13, imagen 2 de 2
    • Slide the disk drive out of the laptop.
  14. HP Envy dv7t-7200 Fan Replacement, Keyboard Assembly: paso 14, imagen 1 de 1
    • Place the laptop on it’s top
    • Remove the two screws that secure the keyboard to the laptop.
  15. HP Envy dv7t-7200 Fan Replacement: paso 15, imagen 1 de 1
    • Stand the laptop on it’s left side with it’s top open.
    • Locate the circular opening in the optical drive slot.
    • Using a plastic opener, press on the keyboard through this opening until it lifts the keyboard away.
  16. HP Envy dv7t-7200 Fan Replacement: paso 16, imagen 1 de 1
    • Place the laptop on it’s back with the front facing you.
    • Using a plastic opener, lift the back of the keyboard towards you releasing it from the lip that holds it.
    • You will hear slight popping noises as the keyboard separates.
  17. HP Envy dv7t-7200 Fan Replacement: paso 17, imagen 1 de 1
    • The keyboard is still attached by two ribbon cables. Lift the keyboard slowly during this step.
    • Lift keyboard up and place upside down on laptop.
  18. HP Envy dv7t-7200 Fan Replacement: paso 18, imagen 1 de 1
    • Release the connectors that attach the keyboard to the laptop.
  19. HP Envy dv7t-7200 Fan Replacement: paso 19, imagen 1 de 1
    • Remove the keyboard.
  20. HP Envy dv7t-7200 Fan Replacement, Motherboard: paso 20, imagen 1 de 1
    • Disconnect the four tabs shown from the laptop.
  21. HP Envy dv7t-7200 Fan Replacement: paso 21, imagen 1 de 1
    • Remove the screw located to the upper left of the disc drive.
  22. HP Envy dv7t-7200 Fan Replacement: paso 22, imagen 1 de 1
    • Pry open the top panel of the laptop with a metal spudger.
  23. HP Envy dv7t-7200 Fan Replacement: paso 23, imagen 1 de 1
    • Remove the screws that hold the motherboard to the frame
  24. HP Envy dv7t-7200 Fan Replacement: paso 24, imagen 1 de 2 HP Envy dv7t-7200 Fan Replacement: paso 24, imagen 2 de 2
    • Lift the right side of the motherboard
    • Slide the motherboard at this angle toward the right
  25. HP Envy dv7t-7200 Fan Replacement: paso 25, imagen 1 de 2 HP Envy dv7t-7200 Fan Replacement: paso 25, imagen 2 de 2
    • Turn the motherboard over
    • Remove the screws that hold the motherboard and the fan together.
Conclusión
Krystal
Miembro Desde 10/16/17
882 Reputación
8 Guías creadas
Equipo
UW Tacoma, Team S3-G3, Liner Fall 2017 Miembro de UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 956
