Saltar al contenido principal
HP Envy dv6-7363cl Fan Replacement
Qué necesitas
  1. HP Envy dv6-7363cl Fan Replacement, Battery: paso 1, imagen 1 de 1
    • Flip the device upside-down so that its bottom is facing up.
  2. HP Envy dv6-7363cl Fan Replacement: paso 2, imagen 1 de 1
    • Push the lever underneath the battery to the left.
  3. HP Envy dv6-7363cl Fan Replacement: paso 3, imagen 1 de 2 HP Envy dv6-7363cl Fan Replacement: paso 3, imagen 2 de 2
    • Lift the battery up out of its socket.
  4. HP Envy dv6-7363cl Fan Replacement, Fan: paso 4, imagen 1 de 1
    • Remove the circled screws from the back panel.
  5. HP Envy dv6-7363cl Fan Replacement: paso 5, imagen 1 de 1
    • Lift and remove the back panel of the device.
  6. HP Envy dv6-7363cl Fan Replacement: paso 6, imagen 1 de 3 HP Envy dv6-7363cl Fan Replacement: paso 6, imagen 2 de 3 HP Envy dv6-7363cl Fan Replacement: paso 6, imagen 3 de 3
    • Flip the laptop back over and carefully pry the keyboard frame out of the device.
  7. HP Envy dv6-7363cl Fan Replacement: paso 7, imagen 1 de 3 HP Envy dv6-7363cl Fan Replacement: paso 7, imagen 2 de 3 HP Envy dv6-7363cl Fan Replacement: paso 7, imagen 3 de 3
    • Lift the keyboard out of the device
    • Carefully remove ribbon cables.
  8. HP Envy dv6-7363cl Fan Replacement: paso 8, imagen 1 de 3 HP Envy dv6-7363cl Fan Replacement: paso 8, imagen 2 de 3 HP Envy dv6-7363cl Fan Replacement: paso 8, imagen 3 de 3
    • Flip device onto its back
    • Remove disk tray and circled screw.
  9. HP Envy dv6-7363cl Fan Replacement: paso 9, imagen 1 de 2 HP Envy dv6-7363cl Fan Replacement: paso 9, imagen 2 de 2
    • Flip device right-side-up and remove ribbon cables from plastic cover beneath keyboard. Remove plastic cover from device.
  10. HP Envy dv6-7363cl Fan Replacement: paso 10, imagen 1 de 3 HP Envy dv6-7363cl Fan Replacement: paso 10, imagen 2 de 3 HP Envy dv6-7363cl Fan Replacement: paso 10, imagen 3 de 3
    • Disconnect red cord from DVD drive and remove DVD drive.
  11. HP Envy dv6-7363cl Fan Replacement: paso 11, imagen 1 de 3 HP Envy dv6-7363cl Fan Replacement: paso 11, imagen 2 de 3 HP Envy dv6-7363cl Fan Replacement: paso 11, imagen 3 de 3
    • Remove circled screws.
  12. HP Envy dv6-7363cl Fan Replacement: paso 12, imagen 1 de 2 HP Envy dv6-7363cl Fan Replacement: paso 12, imagen 2 de 2
    • Disconnect red and white cords from blue circuit board.
  13. HP Envy dv6-7363cl Fan Replacement: paso 13, imagen 1 de 3 HP Envy dv6-7363cl Fan Replacement: paso 13, imagen 2 de 3 HP Envy dv6-7363cl Fan Replacement: paso 13, imagen 3 de 3
    • Gently pull circled pieces from their holsters.
  14. HP Envy dv6-7363cl Fan Replacement: paso 14, imagen 1 de 2 HP Envy dv6-7363cl Fan Replacement: paso 14, imagen 2 de 2
    • Turn device onto its back and remove circled screws from Wi-Fi card.
    • Flip device back over and unscrew disk reader
  15. HP Envy dv6-7363cl Fan Replacement: paso 15, imagen 1 de 1
    • Remove circled screws from blue circuit board and lift fan assembly out of device.
Conclusión
Una persona más ha completado esta guía.
dylananthony
Miembro Desde 10/20/16
564 Reputación
3 Guías creadas
Equipo
2 comentarios
My laptop is a slightly different model and everything provided by the author is likely accurate for their model. I only mention this to caution that your repair may be slightly different depending on your specific model. Mine was different in a few areas though held mostly true with my dv6t-7000. Cheers!
zabadoo - Contestar
Salom menga shu modeldagi kompyuterni ustgi qopqogʻini topib pochta qila olasizmi iloji boʻlsa iltimos nomerim +998991768069 shu nomerga telfon qib bogʻlanishiz mumkin men bilan
Shamsullo Quzratov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 24
Todo El Tiempo: 4,625
